Ga door naar hoofdinhoud
Dell Latitude 3189 Speakers Replacement
Wat je nodig hebt
  1. Dell Latitude 3189 Speakers Replacement, Lower Case: stap 1, afbeelding 1 van 2 Dell Latitude 3189 Speakers Replacement, Lower Case: stap 1, afbeelding 2 van 2
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Speakers Replacement: stap 2, afbeelding 1 van 3 Dell Latitude 3189 Speakers Replacement: stap 2, afbeelding 2 van 3 Dell Latitude 3189 Speakers Replacement: stap 2, afbeelding 3 van 3
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Speakers Replacement: stap 3, afbeelding 1 van 2 Dell Latitude 3189 Speakers Replacement: stap 3, afbeelding 2 van 2
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Speakers Replacement: stap 4, afbeelding 1 van 3 Dell Latitude 3189 Speakers Replacement: stap 4, afbeelding 2 van 3 Dell Latitude 3189 Speakers Replacement: stap 4, afbeelding 3 van 3
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Speakers Replacement, Battery: stap 5, afbeelding 1 van 2 Dell Latitude 3189 Speakers Replacement, Battery: stap 5, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the three 3.2 mm screws that secure the battery.
  6. Dell Latitude 3189 Speakers Replacement: stap 6, afbeelding 1 van 2 Dell Latitude 3189 Speakers Replacement: stap 6, afbeelding 2 van 2
    • Grip the battery and lift it up and out of the chassis.
  7. Dell Latitude 3189 Speakers Replacement, Speakers: stap 7, afbeelding 1 van 1
    • Use the flat end of a spudger to push the white plastic speaker connector out of its motherboard port.
  8. Dell Latitude 3189 Speakers Replacement: stap 8, afbeelding 1 van 2 Dell Latitude 3189 Speakers Replacement: stap 8, afbeelding 2 van 2
    • Lift out the right speaker.
    • Lift out the left speaker.
    • Before removing the speakers make note of how the wire between the right and left speakers are routed within the chassis.
Conclusie
Bryan Pratt
601 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 42
