Ga door naar hoofdinhoud
Dell Latitude 3189 Power Jack Replacement
Wat je nodig hebt
  1. Dell Latitude 3189 Power Jack Replacement, Lower Case: stap 1, afbeelding 1 van 2 Dell Latitude 3189 Power Jack Replacement, Lower Case: stap 1, afbeelding 2 van 2
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Power Jack Replacement: stap 2, afbeelding 1 van 3 Dell Latitude 3189 Power Jack Replacement: stap 2, afbeelding 2 van 3 Dell Latitude 3189 Power Jack Replacement: stap 2, afbeelding 3 van 3
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Power Jack Replacement: stap 3, afbeelding 1 van 2 Dell Latitude 3189 Power Jack Replacement: stap 3, afbeelding 2 van 2
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Power Jack Replacement: stap 4, afbeelding 1 van 3 Dell Latitude 3189 Power Jack Replacement: stap 4, afbeelding 2 van 3 Dell Latitude 3189 Power Jack Replacement: stap 4, afbeelding 3 van 3
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Power Jack Replacement, Power Jack: stap 5, afbeelding 1 van 1
    • Use a spudger to push the charging port connector directly out of its motherboard port.
    • The charging port is located in the top-right corner of the device, near the hinge.
  6. Dell Latitude 3189 Power Jack Replacement: stap 6, afbeelding 1 van 2 Dell Latitude 3189 Power Jack Replacement: stap 6, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the two 3.3 mm screws that secure the power jack to the chassis.
  7. Dell Latitude 3189 Power Jack Replacement: stap 7, afbeelding 1 van 1
    • Slide and lift the power connector port away from the computer.
Conclusie
Bryan Pratt
601 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 45
