Ga door naar hoofdinhoud
Dell Inspiron One 2020 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: stap 1, afbeelding 1 van 3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: stap 1, afbeelding 2 van 3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Dell Inspiron One 2020 Hard Drive Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron One 2020 Hard Drive Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron One 2020 Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Dell Inspiron One 2020 Hard Drive Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron One 2020 Hard Drive Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron One 2020 Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
  4. Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 2 Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 2 van 2
    • Remove the three screws that hold the hard drive cage to the chassis.
  5. Dell Inspiron One 2020 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron One 2020 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Slide the hard drive cage out slightly to access and remove the power and SATA cable.
    • There isn't much slack in these cables, so don't slide the hard drive cage to far.
    • The power and SATA cables are connected together. On most other computers, these connectors are separate.
    • Lift the hard drive cage out.
  6. Dell Inspiron One 2020 Hard Drive Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron One 2020 Hard Drive Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron One 2020 Hard Drive Replacement: stap 6, afbeelding 3 van 3
    • Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
Conclusie
35 andere personen hebben deze handleiding voltooid.
Tyler
4.968 Reputatie
16 handleidingen geschreven
TechForce Lid van TechForce
Business
2 Leden
25 handleidingen geschreven
3 opmerkingen
Thanks for this info this is very useful
Thank you once again
Ketan Valsangkar - Antwoord
Good Job, short and sweet and easy to follow
schmidtrg - Antwoord
Really useful information thank you.
Jessie Colon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 73
Altijd: 35,927
