Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
If your keyboard on your Dell Inspiron N5030 is not working, and you have tried all of the steps on the troubleshooting guide, use this guide to replace your keyboard.
Onderdelen
Geen onderdelen opgegeven.
  1. Turn the computer over on its back so the battery compartment faces towards you. Place your fingers on the small buttons with arrows pointing outwards.
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Grab the battery and pull it towards yourself. Remove the battery.
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Flip over the laptop and open it so that the screen faces you.
    • Flip over the laptop and open it so that the screen faces you.
  6. Use the plastic opening tool and your fingers to pry off the top panel.
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  7. Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  8. Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  9. Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  10. Remove the top keyboard panel.
    • Remove the top keyboard panel.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Gunnar Salazar
128 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-59, Amido Spring 2014 Lid van Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 Leden
5 handleidingen geschreven
What if i broke the blue ribbons connection to the keyboard
oibrahimopeyemi - Antwoord
This solution is quite troublesome and does not explain how to disconnect / re-connect the wide flat keyboard cable. For a simpler solution see :
https://www.youtube.com/watch?v=jWuGb9AA...
Agropecuaria El Sinu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 2,413
