Ga door naar hoofdinhoud
Dell Inspiron N5030 Disc Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron N5030 Disc Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron N5030 Disc Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Dell Inspiron N5030 Disc Drive Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron N5030 Disc Drive Replacement: stap 2, afbeelding 2 van 2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Dell Inspiron N5030 Disc Drive Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. Dell Inspiron N5030 Disc Drive Replacement: stap 4, afbeelding 1 van 1
    • Flip over the laptop and open it so that the screen faces you.
  5. Dell Inspiron N5030 Disc Drive Replacement: stap 5, afbeelding 1 van 1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  6. Dell Inspiron N5030 Disc Drive Replacement: stap 6, afbeelding 1 van 1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  7. Dell Inspiron N5030 Disc Drive Replacement: stap 7, afbeelding 1 van 1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  8. Dell Inspiron N5030 Disc Drive Replacement: stap 8, afbeelding 1 van 1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  9. Dell Inspiron N5030 Disc Drive Replacement: stap 9, afbeelding 1 van 1
    • Remove the top keyboard panel.
  10. Dell Inspiron N5030 Disc Drive Replacement, Disc Drive: stap 10, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to unscrew one 0.6 mm screw located just to the left of the disc drive.
  11. Dell Inspiron N5030 Disc Drive Replacement: stap 11, afbeelding 1 van 1
    • Position your thumbs to push firmly and slide the disc drive to the right through the rectangular hole in the side of the laptop and out.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Charles
579 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-59, Amido Spring 2014 Lid van Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 1,994
