Ga door naar hoofdinhoud
Dell Inspiron N5010 Memory Modules Replacement
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
  1. Dell Inspiron N5010 Memory Modules Replacement, Popping up the Memory Module: stap 2, afbeelding 1 van 2 Dell Inspiron N5010 Memory Modules Replacement, Popping up the Memory Module: stap 2, afbeelding 2 van 2
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
  2. Dell Inspiron N5010 Memory Modules Replacement, Remove the Memory Module: stap 3, afbeelding 1 van 1
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron N5010 Memory Modules Replacement, Align the Notch: stap 4, afbeelding 1 van 2 Dell Inspiron N5010 Memory Modules Replacement, Align the Notch: stap 4, afbeelding 2 van 2
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  4. Dell Inspiron N5010 Memory Modules Replacement, Install the Memory Module: stap 5, afbeelding 1 van 1
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Terrence15
79.243 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.989 handleidingen geschreven
Één opmerking
I have dell Inspiron n5010 laptop with 2gb ram(2gb 1R*8 PC3-10600s-09-11-B2).I need to upgrade ram to 8gb.suggest me exact ram which supports my laptop.if you suggest the buying link,it would be more helpful to me.
Babu j Ramaswamy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 670
