Ga door naar hoofdinhoud
Dell Inspiron N5010 Hard Drive Replacement
Wat je nodig hebt
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  1. Dell Inspiron N5010 Hard Drive Replacement, Remove the Screws: stap 2, afbeelding 1 van 1
    • Remove the four screws that secure the hard-drive assembly.
  2. Dell Inspiron N5010 Hard Drive Replacement, Lifting the Hard Drive Assembly: stap 3, afbeelding 1 van 1
    • Turn the computer over and lift the hard-drive assembly out of the hard-drive bay to disconnect the hard-drive assembly from the connector on the system board.
  3. Dell Inspiron N5010 Hard Drive Replacement, Disconnect the Interposer: stap 4, afbeelding 1 van 1
    • Pull the interposer to disconnect it from the hard drive.
  4. Dell Inspiron N5010 Hard Drive Replacement, Connect the Interposer: stap 5, afbeelding 1 van 1
    • Connect the interposer to the NEW hard drive.
  5. Dell Inspiron N5010 Hard Drive Replacement, Align the Hard Drive Assembly: stap 6, afbeelding 1 van 1
    • Align the hard-drive assembly with the connector on the system board and press the hard-drive assembly into the hard-drive bay until it is fully seated.
  6. Dell Inspiron N5010 Hard Drive Replacement, Replace the Screws: stap 7, afbeelding 1 van 1
    • Turn the computer over and replace the four screws that secure the hard-drive assembly.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Terrence15
79.243 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.989 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 1,940
