Ga door naar hoofdinhoud
Dell Inspiron N4110 RAM Replacement
Wat je nodig hebt
  1. Dell Inspiron N4110 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 RAM Replacement: stap 2, afbeelding 1 van 1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 RAM Replacement: stap 3, afbeelding 1 van 1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 RAM Replacement, RAM: stap 4, afbeelding 1 van 2 Dell Inspiron N4110 RAM Replacement, RAM: stap 4, afbeelding 2 van 2
    • Locate and unscrew the one 2.5x5 mm screw on the cover.
    • The screw does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
  5. Dell Inspiron N4110 RAM Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron N4110 RAM Replacement: stap 5, afbeelding 2 van 2
    • Remove RAM cover from the laptop.
  6. Dell Inspiron N4110 RAM Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron N4110 RAM Replacement: stap 6, afbeelding 2 van 2
    • Use your fingers to separate the two metal clips from the RAM.
    • The RAM will lift up when properly separated. Do not force the RAM out of the clips.
  7. Dell Inspiron N4110 RAM Replacement: stap 7, afbeelding 1 van 1
    • Remove the RAM from the computer.
    • Be careful as to not touch the metal on the bottom of the RAM. This can cause damage.
    • The RAM should be placed on a non-conductive surface.
Conclusie
Olivia
773 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S5-G1, Peak Spring 2018 Lid van UMass Dartmouth, Team S5-G1, Peak Spring 2018
UMASSD-PEAK-S18S5G1
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 767
