Ga door naar hoofdinhoud
Dell Inspiron N4010 Memory Modules Replacement
  1. Dell Inspiron N4010 Memory Modules Replacement, Popping up the Memory Module: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
  2. Dell Inspiron N4010 Memory Modules Replacement, Remove the Memory Module: stap 2, afbeelding 1 van 1
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron N4010 Memory Modules Replacement, Align the Notch: stap 3, afbeelding 1 van 1
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  4. Dell Inspiron N4010 Memory Modules Replacement, Sliding the Memory Module: stap 4, afbeelding 1 van 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Eindstreep
Terrence15
79.243 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.989 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 460
