Ga door naar hoofdinhoud
Dell Inspiron N4010 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron N4010 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Keyboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron N4010 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 3 Dell Inspiron N4010 Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 3 Dell Inspiron N4010 Keyboard Replacement, Keyboard: stap 4, afbeelding 3 van 3
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    There Is one More screw that needs to be removed!!!
    Guillermo Zepeda - Antwoord
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Keyboard Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron N4010 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Keyboard Replacement: stap 8, afbeelding 1 van 2 Dell Inspiron N4010 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Keyboard Replacement: stap 9, afbeelding 1 van 2 Dell Inspiron N4010 Keyboard Replacement: stap 9, afbeelding 2 van 2
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
Conclusie
Jonathan Sellier
952 Reputatie
7 handleidingen geschreven
USF Tampa, Team S13-G5, Boczar Fall 2017 Lid van USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 Leden
9 handleidingen geschreven
Één opmerking
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 978
