Ga door naar hoofdinhoud
Dell Inspiron N4010 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron N4010 Hard Drive Replacement, Remove the Screws: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Dell Inspiron N4010 Hard Drive Replacement, Sliding the Hard-Drive Assembly: stap 2, afbeelding 1 van 1
    • Slide the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Inspiron N4010 Hard Drive Replacement, Lifting the Hard Drive Assembly: stap 3, afbeelding 1 van 1
    • Lift the hard-drive assembly away from the system board.
  4. Dell Inspiron N4010 Hard Drive Replacement, Remove the Screws: stap 4, afbeelding 1 van 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron N4010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: stap 5, afbeelding 1 van 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron N4010 Hard Drive Replacement, Align the Screw Holes: stap 6, afbeelding 1 van 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
  7. Dell Inspiron N4010 Hard Drive Replacement, Sliding the Hard-Drive Assembly: stap 7, afbeelding 1 van 1
    • Slide and push the hard-drive assembly to connect it to connector on the system board.
  8. Dell Inspiron N4010 Hard Drive Replacement, Replace the Screws: stap 8, afbeelding 1 van 1
    • Replace the two screws that secure the hard-drive assembly to the system board.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Terrence15
79.243 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.989 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 824
