Ga door naar hoofdinhoud
Dell Inspiron N4010 Hard Disk Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron N4010 Hard Disk Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron N4010 Hard Disk Drive Replacement: stap 2, afbeelding 2 van 2
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 3, afbeelding 1 van 1
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Hard Disk Drive Replacement, Keyboard: stap 4, afbeelding 1 van 3 Dell Inspiron N4010 Hard Disk Drive Replacement, Keyboard: stap 4, afbeelding 2 van 3 Dell Inspiron N4010 Hard Disk Drive Replacement, Keyboard: stap 4, afbeelding 3 van 3
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron N4010 Hard Disk Drive Replacement: stap 7, afbeelding 2 van 2
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 8, afbeelding 1 van 2 Dell Inspiron N4010 Hard Disk Drive Replacement: stap 8, afbeelding 2 van 2
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 9, afbeelding 1 van 2 Dell Inspiron N4010 Hard Disk Drive Replacement: stap 9, afbeelding 2 van 2
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
  9. Dell Inspiron N4010 Hard Disk Drive Replacement, Top Cover: stap 10, afbeelding 1 van 2 Dell Inspiron N4010 Hard Disk Drive Replacement, Top Cover: stap 10, afbeelding 2 van 2
    • Remove the indicated 5.7mm screws.
    • Remove the smaller 3mm screws from underneath the battery compartment.
  10. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 11, afbeelding 1 van 2 Dell Inspiron N4010 Hard Disk Drive Replacement: stap 11, afbeelding 2 van 2
    • With a plastic spudger, pry away the silver top cover from the black casing.
    • Move the tool to the right and left along the seams to fully disconnect the cover.
  11. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 12, afbeelding 1 van 1
    • Disconnect the indicated ribbon cables underneath where the keyboard sits.
  12. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 13, afbeelding 1 van 1
    • Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right
  13. Dell Inspiron N4010 Hard Disk Drive Replacement, Fan: stap 14, afbeelding 1 van 2 Dell Inspiron N4010 Hard Disk Drive Replacement, Fan: stap 14, afbeelding 2 van 2
    • Peel back the yellow tape to expose the ribbon connector.
    • Unplug the ribbon cable from the motherboard.
  14. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 15, afbeelding 1 van 1
    • Unplug the 3-wire connector from the motherboard.
  15. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 16, afbeelding 1 van 1
    • Unscrew the indicated 5.6mm screws with the #0 Phillips Head Screwdriver.
  16. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 17, afbeelding 1 van 1
    • Remove the fan from the device.
  17. Dell Inspiron N4010 Hard Disk Drive Replacement, Motherboard: stap 18, afbeelding 1 van 2 Dell Inspiron N4010 Hard Disk Drive Replacement, Motherboard: stap 18, afbeelding 2 van 2
    • Unscrew the two screws on the right hand speaker with the #0 Phillips Head.
    • Unplug the speaker connector from the motherboard.
  18. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 19, afbeelding 1 van 1
    • Reaching under the daughter board, disconnect the connector.
    • It will be under the board in the area indicated.
  19. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 20, afbeelding 1 van 1
    • Unscrew the indicated 5.6mm screws with a Phillips #0 screwdriver.
  20. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 21, afbeelding 1 van 1
    • The motherboard can now be removed by pulling upwards, tilting it to the left of the laptop until the connectors clear the body of the laptop.
  21. Dell Inspiron N4010 Hard Disk Drive Replacement, Hard Disk Drive: stap 22, afbeelding 1 van 1
    • Unscrew the 6 Phillips head screws holding the hard drive to the motherboard with the #0 driver head.
  22. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 23, afbeelding 1 van 2 Dell Inspiron N4010 Hard Disk Drive Replacement: stap 23, afbeelding 2 van 2
    • Slide the hard drive towards the center of the motherboard.
    • The hard drive should come away from the motherboard.
  23. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 24, afbeelding 1 van 1
    • Undo the 2 screws with the #0 Phillips head driver on either side of the hard drive assembly.
  24. Dell Inspiron N4010 Hard Disk Drive Replacement: stap 25, afbeelding 1 van 2 Dell Inspiron N4010 Hard Disk Drive Replacement: stap 25, afbeelding 2 van 2
    • Slide the assembly off of the hard drive.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jonathan Sellier
952 Reputatie
7 handleidingen geschreven
USF Tampa, Team S13-G5, Boczar Fall 2017 Lid van USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 Leden
9 handleidingen geschreven
6 opmerkingen
I hope somebody at Dell lost their job over this design.
Jason Northrup - Antwoord
hahaha i agree
Robert G -
The N4010 is definitely a beautiful-looking set, but it’s sure a tough nut to crack when it’s time to repair something inside it, lol :-D
Terry McKean -
A bunch of screws not listed have to be removed also they are in proximity of the cmos battery I imagine someone will damage their machine following this NOT GOOD! I signed up just to post this! Look for screws with the LETTER B they need removing before the board can come out! ifixit should screen their submissions better
ptooti - Antwoord
In step 20 we remove the screws
Jonathan Sellier -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 51
Altijd: 7,027
