Ga door naar hoofdinhoud
Dell Inspiron Mini 1012: Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron Mini 1012: Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the battery
  2. Dell Inspiron Mini 1012: Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Dell Inspiron Mini 1012: Keyboard Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron Mini 1012: Keyboard Replacement: stap 3, afbeelding 2 van 2
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  4. Dell Inspiron Mini 1012: Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Marie K Bordley
241 Reputatie
2 handleidingen geschreven
Ohio State, Team 1-1, Buehl Fall 2014 Lid van Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
4 Leden
4 handleidingen geschreven
Één opmerking
After keyboard open, You can change HDD or Memory as you like.
최희욱 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 3,294
