Ga door naar hoofdinhoud
Dell Inspiron Mini 1012 Screen Replacement
Wat je nodig hebt
  1. Dell Inspiron Mini 1012 Screen Replacement, Screen: stap 1, afbeelding 1 van 3 Dell Inspiron Mini 1012 Screen Replacement, Screen: stap 1, afbeelding 2 van 3 Dell Inspiron Mini 1012 Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Remove the battery from the device for safety. Slide the two tabs on the bottom of the computer to the unlocked position, and gently lift up the battery.
    • Remove the two rubber pieces at the bottom of the screen and remove the screws located behind them.
    • Carefully remove the plastic casing from the device.
  2. Dell Inspiron Mini 1012 Screen Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron Mini 1012 Screen Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron Mini 1012 Screen Replacement: stap 2, afbeelding 3 van 3
    • Remove the four screws on each corner of the screen. Then remove the screws located on the side of the screen.
    • Carefully unplug the ribbon on the back of the screen.
  3. Dell Inspiron Mini 1012 Screen Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron Mini 1012 Screen Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron Mini 1012 Screen Replacement: stap 3, afbeelding 3 van 3
    • Place the new screen onto the device and plug the ribbon in.
    • Replace the screws on the side of the screen.
  4. Dell Inspiron Mini 1012 Screen Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron Mini 1012 Screen Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron Mini 1012 Screen Replacement: stap 4, afbeelding 3 van 3
    • Snap on the plastic screen cover and replace the two screws and the rubber pieces at the bottom of the screen.
    • Turn the computer over and put the battery back in.
Conclusie
To reassemble your device, follow guide instructions.
sabinabarajas
372 Reputatie
3 handleidingen geschreven
Gateway, Team 2-2, Kuhn Fall 2015 Lid van Gateway, Team 2-2, Kuhn Fall 2015
GCC-KUHN-F15S2G2
1 Lid
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 1,346
