Ga door naar hoofdinhoud
Dell Inspiron Mini 1012 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Unlock the two tabs on the bottom of the laptop.
    • Use your fingernail or a spudger to pull the battery pack out of the laptop.
  2. Dell Inspiron Mini 1012 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the three screws with a Phillips #00 screwdriver.
  3. Dell Inspiron Mini 1012 Keyboard Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron Mini 1012 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Insert the spudger between the top of the keyboard and the laptop body.
    • Carefully pry the keyboard up.
    • Be gentle! You don't want to damage the laptops ribbon cable connector by pulling too hard.
    • It's not recommended to use a metal spudger for this repair as the photo shows. A regular nylon spudger will work just fine.
  4. Dell Inspiron Mini 1012 Keyboard Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron Mini 1012 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Unlock the connector to release the ribbon cable.
    • Carefully pull on the clear tab to remove the keyboard from the device.
  5. Dell Inspiron Mini 1012 Keyboard Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron Mini 1012 Keyboard Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron Mini 1012 Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Take the new keyboard and insert the ribbon cable into the connector on the laptop.
    • Lay the keyboard back onto the device and gently snap it back into place.
Conclusie
To reassemble your device, follow these instructions in reverse order starting at step two.
sabinabarajas
372 Reputatie
3 handleidingen geschreven
Gateway, Team 2-2, Kuhn Fall 2015 Lid van Gateway, Team 2-2, Kuhn Fall 2015
GCC-KUHN-F15S2G2
1 Lid
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 639
