Ga door naar hoofdinhoud
Dell Inspiron Mini 1012 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron Mini 1012 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Inspiron Mini 1012 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Inspiron Mini 1012 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Turn the device over so the bottom is facing upwards.
    • Slide the two tabs beside the lock icons to the unlocked position.
    • Find the notch located in the center between the two tabs and lift up on the battery to remove it.
    • To replace the battery, align the three notches on the battery with the grooves on the device. Snap the battery back onto the device, and it will lock in place.
Conclusie
To reassemble, place the new battery in the three slots. Lock the battery back in place.
sabinabarajas
372 Reputatie
3 handleidingen geschreven
Gateway, Team 2-2, Kuhn Fall 2015 Lid van Gateway, Team 2-2, Kuhn Fall 2015
GCC-KUHN-F15S2G2
1 Lid
6 handleidingen geschreven
Één opmerking
So, I’ve installed the new battery and the mini 1012 won’t recognize or charge it. Now what?
complainingparty - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 1,388
