1. Remove the battery
    • Remove the battery
  2. Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  5. Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Marie K Bordley
223 Reputatie
2 handleidingen geschreven
Ohio State, Team 1-1, Buehl Fall 2014 Lid van Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
4 Leden
Één commentaar
After keyboard open, You can change HDD or Memory as you like.
최희욱 - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 6
Afgelopen 30 Dagen: 25
Altijd: 2,683
