Ga door naar hoofdinhoud
Dell Inspiron Mini 10 Palm Rest Replacement
Wat je nodig hebt
  1. Dell Inspiron Mini 10 Palm Rest Replacement, Battery: stap 1, afbeelding 1 van 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Palm Rest Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Palm Rest Replacement, Palm Rest: stap 3, afbeelding 1 van 1
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Palm Rest Replacement: stap 4, afbeelding 1 van 1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
Conclusie
Bariso Shuba
270 Reputatie
3 handleidingen geschreven
UW Tacoma, Team 1-4, Rose Fall 2016 Lid van UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 332
