Ga door naar hoofdinhoud
Dell Inspiron Mini 10 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron Mini 10 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  4. Dell Inspiron Mini 10 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  5. Dell Inspiron Mini 10 Keyboard Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron Mini 10 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  6. Dell Inspiron Mini 10 Keyboard Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron Mini 10 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
Conclusie
Danielle Jarecki
334 Reputatie
5 handleidingen geschreven
UW Tacoma, Team 1-4, Rose Fall 2016 Lid van UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,383
