Ga door naar hoofdinhoud
Dell Inspiron M5110 Palmrest Replacement
Wat je nodig hebt
  1. Dell Inspiron M5110 Palmrest Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Palmrest Replacement: stap 2, afbeelding 1 van 1
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Palmrest Replacement: stap 3, afbeelding 1 van 1
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Palmrest Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Palmrest Replacement: stap 5, afbeelding 1 van 1
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Palmrest Replacement: stap 6, afbeelding 1 van 1
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Palmrest Replacement: stap 7, afbeelding 1 van 1
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Palmrest Replacement: stap 8, afbeelding 1 van 1
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Palmrest Replacement: stap 9, afbeelding 1 van 1
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
  10. Dell Inspiron M5110 Palmrest Replacement, Palmrest: stap 10, afbeelding 1 van 1
    • Turn the computer over and remove the six screws that secure the palmrest assembly
  11. Dell Inspiron M5110 Palmrest Replacement: stap 11, afbeelding 1 van 1
    • Turn the computer over and open the display as far as possible and remove the four 5 mm Phillips # 0 screw holding the palmrest in place.
  12. Dell Inspiron M5110 Palmrest Replacement: stap 12, afbeelding 1 van 2 Dell Inspiron M5110 Palmrest Replacement: stap 12, afbeelding 2 van 2
    • Disconnect the power button board cable, touch pad cable and the hot key board cable from the connectors.
  13. Dell Inspiron M5110 Palmrest Replacement: stap 13, afbeelding 1 van 2 Dell Inspiron M5110 Palmrest Replacement: stap 13, afbeelding 2 van 2
    • Use a plastic opening tool to carefully pry out the palmrest assembly and lift it off the computer base.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Larain
387 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-3, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-3, Catania Fall 2016
UMASSD-CATANIA-F16S4G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 182
