Ga door naar hoofdinhoud
Dell Inspiron M5030 Processor Replacement
Wat je nodig hebt
  1. Dell Inspiron M5030 Processor Replacement, Keyboard: stap 1, afbeelding 1 van 2 Dell Inspiron M5030 Processor Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop.
    • Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
    If you are removing only the keyboard, you only need to remove two screws.
    1 - Remove the screw to the immediate right of the INSPIRON M5030 label.
    2 - To the top left of the INSPIRON M5030 label, there are two screws. Remove the left one.
    I marked the two screw locations with green, for clarification.
    - https://ibb.co/nz4rNG
    - https://postimg.org/image/67kinagal/
    Robert Johnson - Antwoord
  2. Dell Inspiron M5030 Processor Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron M5030 Processor Replacement: stap 2, afbeelding 2 van 2
    • Turn the laptop over and open the lid.
    • Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
    • With one of your hands, push the leftmost tab down with the plastic opening tool (above the F1 key). With your other hand, lift the left side of the keyboard.
    • Push the middle tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the F6 key).
    • Push the rightmost tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the PrntScr key). The keyboard should be loosened from the laptop after these steps.
    for your last bullet, maybe clarify saying "push the next to tabs with the plastic opening tool…"
    Katie Pepi - Antwoord
  3. Dell Inspiron M5030 Processor Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron M5030 Processor Replacement: stap 3, afbeelding 2 van 2
    • After the top edge of the keyboard is loose, pull up on the keyboard gently.
    • Do not pull the keyboard up forcefully as the keyboard is still attached to the laptop by a ribbon.
  4. Dell Inspiron M5030 Processor Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron M5030 Processor Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron M5030 Processor Replacement: stap 4, afbeelding 3 van 3
    • Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard.
    • Locate the blue end of the ribbon which is connected to the motherboard.
    • Lift up the black flap on the connector and gently pull the ribbon away from the connector which is parallel to the motherboard.
    • Lift the keyboard up and off of the motherboard. Detach the blue end of the ribbon from the connector.
  5. Dell Inspiron M5030 Processor Replacement, Surface Around the Keyboard: stap 5, afbeelding 1 van 2 Dell Inspiron M5030 Processor Replacement, Surface Around the Keyboard: stap 5, afbeelding 2 van 2
    • Disconnect the blue tab located just above the touch pad of the laptop.
    how do you disconnect speaker cable from it’s connector do those tabs lift up push down or do you just pull them out never seen connectors like them before and i am a bit concerned i might break connector.
    Garry
    garry gibbons - Antwoord
    • Lift the black locking tab a small way up, away from the Green PCB, until a click is heard. Before pullinh on blue tab.
  6. Dell Inspiron M5030 Processor Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron M5030 Processor Replacement: stap 7, afbeelding 2 van 2
    • Use a plastic opening tool to pry up the plastic covering of the laptop by wedging it underneath one side of the covering and lift up.
    • Do not lift off the cover all the way as it is still connected by two wires on the side nearest to the screen.
  7. Dell Inspiron M5030 Processor Replacement: stap 8, afbeelding 1 van 3 Dell Inspiron M5030 Processor Replacement: stap 8, afbeelding 2 van 3 Dell Inspiron M5030 Processor Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the white block of wires which is the right-most wire connecting the covering to the laptop.
  8. Dell Inspiron M5030 Processor Replacement: stap 9, afbeelding 1 van 3 Dell Inspiron M5030 Processor Replacement: stap 9, afbeelding 2 van 3 Dell Inspiron M5030 Processor Replacement: stap 9, afbeelding 3 van 3
    • Disconnect the wire with the blue tab which is the left-most wire connecting the covering to the laptop.
    • You can now remove the plastic covering.
  9. Dell Inspiron M5030 Processor Replacement, Fan: stap 10, afbeelding 1 van 3 Dell Inspiron M5030 Processor Replacement, Fan: stap 10, afbeelding 2 van 3 Dell Inspiron M5030 Processor Replacement, Fan: stap 10, afbeelding 3 van 3
    • Remove the tape from the fan, but do not remove the tape from the wire.
    • Move the wire away from the fan.
    • There are ridges along the top of the fan which indicate where the wire should sit when you put the fan back.
  10. Dell Inspiron M5030 Processor Replacement: stap 11, afbeelding 1 van 1
    • Locate the yellow/black/red wires and find the white plastic block where they end.
  11. Dell Inspiron M5030 Processor Replacement: stap 12, afbeelding 1 van 2 Dell Inspiron M5030 Processor Replacement: stap 12, afbeelding 2 van 2
    • Using two fingers (one on either side of the block) or two plastic opening tools (one on either side of the block), pinch the bottom of the block and lift up to remove the block.
  12. Dell Inspiron M5030 Processor Replacement: stap 13, afbeelding 1 van 3 Dell Inspiron M5030 Processor Replacement: stap 13, afbeelding 2 van 3 Dell Inspiron M5030 Processor Replacement: stap 13, afbeelding 3 van 3
    • Unscrew the four screws from the heat sink with a Phillips #0 screwdriver.
    • You do not need to remove the screws completely from the heat sink.
  13. Dell Inspiron M5030 Processor Replacement, Processor: stap 14, afbeelding 1 van 3 Dell Inspiron M5030 Processor Replacement, Processor: stap 14, afbeelding 2 van 3 Dell Inspiron M5030 Processor Replacement, Processor: stap 14, afbeelding 3 van 3
    • Remove the the black screw above the processor with a flathead screwdriver.
    maybe circle the processor in the first picture for this step. i am not familiar with what the mother boards of computers look like and had no idea what the processor was in this image!
  14. Dell Inspiron M5030 Processor Replacement: stap 15, afbeelding 1 van 3 Dell Inspiron M5030 Processor Replacement: stap 15, afbeelding 2 van 3 Dell Inspiron M5030 Processor Replacement: stap 15, afbeelding 3 van 3
    • Grab the sides of the processor with your thumb and forefinger to remove the processor.
    Remember to apply Thermal Compound on CPU before replacing the Heat Sink
    cushtydog - Antwoord
    would that make the computer not turn on afterwards?
    Sarala Wallin -
    I would not prevent the computer from starting up, however it could prevent effective cooling causing damage. You should be using some kind of grounding device when touching the cpu.
    Justin Hippensteel - Antwoord
    Easy, peazy thanks to the excellent verbal description and pics! Many thanks.
    James Haden - Antwoord
Conclusie
6 andere personen hebben deze handleiding voltooid.
Jenine Quintana
440 Reputatie
1 Handleiding geschreven
Cal Poly, Team 3-44, Maness Spring 2014 Lid van Cal Poly, Team 3-44, Maness Spring 2014
CPSU-MANESS-S14S3G44
4 Leden
6 handleidingen geschreven
Één opmerking
Is this the right part number for a cpu replacement for a dell inspiron m5030: PART # 3PDDV?
desertsun15 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 6,850
