Inleiding
This guide will teach you how to remove and replace the keyboard on your Dell Inspiron M5030.
Wat je nodig hebt
Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop.
Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
Turn the laptop over and open the lid.
Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
With one of your hands, push the leftmost tab down with the plastic opening tool (above the F1 key). With your other hand, lift the left side of the keyboard.
Push the middle tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the F6 key).
Push the rightmost tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the PrntScr key). The keyboard should be loosened from the laptop after these steps.
for your last bullet, maybe clarify saying "push the next to tabs with the plastic opening tool…"
Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard.
Locate the blue end of the ribbon which is connected to the motherboard.
Lift up the black flap on the connector and gently pull the ribbon away from the connector which is parallel to the motherboard.
Lift the keyboard up and off of the motherboard. Detach the blue end of the ribbon from the connector.
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Do you know any ways to replace 4 keys Spacebar,B,N and the Slash/Question Mark are broken plz help
The keyboard is best handled as a whole part replacement. You can find M5030 replacement keyboards for about $10 on Amazon/eBay.
If you are removing only the keyboard, you only need to remove two screws.
1 - Remove the screw to the immediate right of the INSPIRON M5030 label.
2 - To the top left of the INSPIRON M5030 label, there are two screws. Remove the left one.
I marked the two screw locations with green, for clarification.
- https://ibb.co/nz4rNG
- https://postimg.org/image/67kinagal/
Robert Johnson - Antwoord
