Ga door naar hoofdinhoud
Dell Inspiron M5010 Palm Rest Replacement
Wat je nodig hebt
  1. Dell Inspiron M5010 Palm Rest Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron M5010 Palm Rest Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 Palm Rest Replacement, Remove keyboard retaining screw: stap 2, afbeelding 1 van 1
    • Remove Keyboard retaining screw from bottom of laptop.
  3. Dell Inspiron M5010 Palm Rest Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron M5010 Palm Rest Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron M5010 Palm Rest Replacement: stap 3, afbeelding 3 van 3
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  4. Dell Inspiron M5010 Palm Rest Replacement: stap 4, afbeelding 1 van 1
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  5. Dell Inspiron M5010 Palm Rest Replacement: stap 5, afbeelding 1 van 1
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
  6. Dell Inspiron M5010 Palm Rest Replacement, Palm Rest: stap 6, afbeelding 1 van 1
    • Flip the laptop, so the bottom of the laptop is facing up.
    • Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
  7. Dell Inspiron M5010 Palm Rest Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron M5010 Palm Rest Replacement: stap 7, afbeelding 2 van 2
    • Flip the laptop back over, so that the top of the laptop is facing up.
    • Open the laptop.
    • Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
  8. Dell Inspiron M5010 Palm Rest Replacement: stap 8, afbeelding 1 van 1
    • Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
  9. Dell Inspiron M5010 Palm Rest Replacement: stap 9, afbeelding 1 van 3 Dell Inspiron M5010 Palm Rest Replacement: stap 9, afbeelding 2 van 3 Dell Inspiron M5010 Palm Rest Replacement: stap 9, afbeelding 3 van 3
    • Carefully unsnap and remove the palm rest.
    • Place your fingers inside the large circle in the lower right corner to get a good grip.
Conclusie
April Poucher
1.164 Reputatie
10 handleidingen geschreven
Clemson, Team 1-5, Benson Fall 2014 Lid van Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 524
