Ga door naar hoofdinhoud
Dell Inspiron M5010 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron M5010 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron M5010 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 Keyboard Replacement, Remove keyboard retaining screw: stap 2, afbeelding 1 van 1
    • Remove Keyboard retaining screw from bottom of laptop.
  3. Dell Inspiron M5010 Keyboard Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron M5010 Keyboard Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron M5010 Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  4. Dell Inspiron M5010 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  5. Dell Inspiron M5010 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
April Poucher
1.164 Reputatie
10 handleidingen geschreven
Clemson, Team 1-5, Benson Fall 2014 Lid van Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 816
