Ga door naar hoofdinhoud
Dell Inspiron E1705 Upper Case and Screen Replacement
Wat je nodig hebt
  1. Dell Inspiron E1705 Upper Case and Screen Replacement, Upper Case and Screen: stap 1, afbeelding 1 van 1
    • Use a spudger to remove the six rubber nibs and 2 plastic pieces on the bezel of the display.
    • Remove the eight Phillips #0 screws hidden under the rubber nibs and plastic pieces.
  2. Dell Inspiron E1705 Upper Case and Screen Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron E1705 Upper Case and Screen Replacement: stap 2, afbeelding 2 van 2
    • Pry the plastic bezel from the back plate using a plastic opening tool.
    • Remove the plastic bezel entirely and set it aside.
  3. Dell Inspiron E1705 Upper Case and Screen Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron E1705 Upper Case and Screen Replacement: stap 3, afbeelding 2 van 2
    • Remove the 4 screws along the left and right sides of the screen. There are 8 screws in total.
  4. Dell Inspiron E1705 Upper Case and Screen Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron E1705 Upper Case and Screen Replacement: stap 4, afbeelding 2 van 2
    • Use the spudger to separate the screen from the back case.
    • Hold the screen in one hand and tilt the back case away from you.
    • The screen is connected to the back case by two leads.
  5. Dell Inspiron E1705 Upper Case and Screen Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron E1705 Upper Case and Screen Replacement: stap 5, afbeelding 2 van 2
    • Remove the two leads from the screen. They will stay connected to the computer.
    • Do not touch the white tape on your replacement monitor.
    • Remove the screen carefully.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Evan Fairchild
613 Reputatie
4 handleidingen geschreven
Cal Poly, Team 22-5, Maness Fall 2010 Lid van Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 7,056
