Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Before any work can be done ensure that the laptop is powered off.
Use either the power button on the computer or issue a shutdown from the operating system.
Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
Locate the battery release switch on the bottom of the laptop.
Once located slide the switch into the unlock position.
Locate the “lip” on the laptop to lift the battery outside of the compartment.
Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
Once the new battery has been acquired take the battery and place it in the empty battery slot.
Slide the switch into the lock position to secure the new battery.
