Ga door naar hoofdinhoud
Dell Inspiron E1405 LCD Screen Replacement
Wat je nodig hebt
  1. Dell Inspiron E1405 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 LCD Screen Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron E1405 LCD Screen Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron E1405 LCD Screen Replacement: stap 2, afbeelding 3 van 3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: stap 3, afbeelding 1 van 3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: stap 3, afbeelding 2 van 3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: stap 3, afbeelding 3 van 3
    • Use your fingers or a spudger to remove the six small rubber covers off the display assembly.
    • Remove the six 5.7 mm screws with a Phillips #00 screwdriver.
  4. Dell Inspiron E1405 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Use your fingers to gently pry the front bezel off the display assembly. Start at a corner and work your way around.
    • Remove the front display bezel when it comes free.
  5. Dell Inspiron E1405 LCD Screen Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron E1405 LCD Screen Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron E1405 LCD Screen Replacement: stap 5, afbeelding 3 van 3
    • Remove the three 3.6 mm screws using a Phillips #00 screwdriver on both sides of the display.
    • Remove the LCD screen from the display assembly.
  6. Dell Inspiron E1405 LCD Screen Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron E1405 LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Unplug the VGA cable by pushing the two metal sides towards the middle of the strip.
    • Gently pull the VGA cable away to release the strip.
  7. Dell Inspiron E1405 LCD Screen Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron E1405 LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Remove the next connection by pressing the two metal sides towards the middle. Then gently pull up the ribbon.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sarah Neal Secrest
597 Reputatie
5 handleidingen geschreven
Texas Tech, Team S8-G3, Bennett Spring 2017 Lid van Texas Tech, Team S8-G3, Bennett Spring 2017
TTU-BENNETT-S17S8G3
3 Leden
Één opmerking
I need complete body *Dell INSPIRON E1405 .
St Master Fun - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 499
