Ga door naar hoofdinhoud
Dell Inspiron E1405 Heat Sink Replacement
Wat je nodig hebt
  1. Dell Inspiron E1405 Heat Sink Replacement, Battery: stap 1, afbeelding 1 van 1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 Heat Sink Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron E1405 Heat Sink Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron E1405 Heat Sink Replacement: stap 2, afbeelding 3 van 3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: stap 3, afbeelding 1 van 3 Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: stap 3, afbeelding 2 van 3 Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: stap 3, afbeelding 3 van 3
    • Remove/loosen the eight 4.8mm screws with a #1 Phillips screwdriver securing the bottom panel.
    • Remove the bottom panel.
  4. Dell Inspiron E1405 Heat Sink Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron E1405 Heat Sink Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron E1405 Heat Sink Replacement: stap 4, afbeelding 3 van 3
    • Loosen the five 5.5mm screws with a #1 Phillips screwdriver securing the heat sink and clean it with compressed air
    • Gently lift the heat sink from the side, as indicated in the picture.
Conclusie
Sarah Neal Secrest
597 Reputatie
5 handleidingen geschreven
Texas Tech, Team S8-G3, Bennett Spring 2017 Lid van Texas Tech, Team S8-G3, Bennett Spring 2017
TTU-BENNETT-S17S8G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 248
