Inleiding
This content will describe the procedure for replacing the WIFI Card.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95
Flip the computer over and place it on a clean level surface.
Loosen the screws using a size #0 Phillips screwdriver.
Gently pry up on the gold antennae connections using a spudger.
Gently pry open both retaining clips on either side of the WiFi card using a spudger.
Één andere persoon heeft deze handleiding voltooid.
