Ga door naar hoofdinhoud
Dell Inspiron 9300 Trackpad Replacement
Wat je nodig hebt
  1. Dell Inspiron 9300 Trackpad Replacement, Trackpad: stap 1, afbeelding 1 van 1
    • Remove the battery in to order avoid damaging internal components.
  2. Dell Inspiron 9300 Trackpad Replacement: stap 2, afbeelding 1 van 1
    • Remove the twelve 6mm Phillips case screws from the bottom of the case.
  3. Dell Inspiron 9300 Trackpad Replacement: stap 3, afbeelding 1 van 1
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
  4. Dell Inspiron 9300 Trackpad Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 9300 Trackpad Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 9300 Trackpad Replacement: stap 4, afbeelding 3 van 3
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard
  5. Dell Inspiron 9300 Trackpad Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 9300 Trackpad Replacement: stap 5, afbeelding 2 van 2
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  6. Dell Inspiron 9300 Trackpad Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 9300 Trackpad Replacement: stap 6, afbeelding 2 van 2
    • Remove the seven 6mm Phillips scres holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger
  7. Dell Inspiron 9300 Trackpad Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 9300 Trackpad Replacement: stap 7, afbeelding 2 van 2
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger
    • Remove the trackpad ribbon cable from the motherboard using a spudger
  8. Dell Inspiron 9300 Trackpad Replacement: stap 8, afbeelding 1 van 1
    • Pull up and away on the uppercase to remove.
Conclusie
Steven Faulkner
214 Reputatie
2 handleidingen geschreven
USF Tampa, Team 16-6, Eyestone Fall 2016 Lid van USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 183
