Ga door naar hoofdinhoud
Dell Inspiron 9300 Speaker System Replacement
Wat je nodig hebt
  1. Dell Inspiron 9300 Speaker System Replacement, Prerequisite Only: stap 1, afbeelding 1 van 2 Dell Inspiron 9300 Speaker System Replacement, Prerequisite Only: stap 1, afbeelding 2 van 2
    • Remove the battery prior to working on any internal components.
    • Remove the twelve 6mm Phillips screws from the bottom of the case.
    • Remove the battery before working on internal components to ensure a safe working environment.
  2. Dell Inspiron 9300 Speaker System Replacement: stap 2, afbeelding 1 van 1
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
  3. Dell Inspiron 9300 Speaker System Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 9300 Speaker System Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 9300 Speaker System Replacement: stap 3, afbeelding 3 van 3
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard.
  4. Dell Inspiron 9300 Speaker System Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 9300 Speaker System Replacement: stap 4, afbeelding 2 van 2
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  5. Dell Inspiron 9300 Speaker System Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 9300 Speaker System Replacement: stap 5, afbeelding 2 van 2
    • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger.
  6. Dell Inspiron 9300 Speaker System Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 9300 Speaker System Replacement: stap 6, afbeelding 2 van 2
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
    • Remove the trackpad ribbon cable from the motherboard using a spudger.
  7. Dell Inspiron 9300 Speaker System Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 9300 Speaker System Replacement: stap 7, afbeelding 2 van 2
    • Pull up and away on the track pad to expose the internal components below.
  8. Dell Inspiron 9300 Speaker System Replacement, Speaker System: stap 8, afbeelding 1 van 1
    • Remove the two 3mm Phillips screws holding the CD-ROM drive in place.
    • Slide the CD-ROM drive out of the lower case.
  9. Dell Inspiron 9300 Speaker System Replacement: stap 9, afbeelding 1 van 2 Dell Inspiron 9300 Speaker System Replacement: stap 9, afbeelding 2 van 2
    • Use a spudger to disconnect the subwoofer cable.
    • Repeat for the adjacent speaker connector.
  10. Dell Inspiron 9300 Speaker System Replacement: stap 10, afbeelding 1 van 1
    • Pry away the black tape that holds the sound system wires in place.
  11. Dell Inspiron 9300 Speaker System Replacement: stap 11, afbeelding 1 van 2 Dell Inspiron 9300 Speaker System Replacement: stap 11, afbeelding 2 van 2
    • Remove the 7mm Phillips screws that hold the subwoofer in place.
    • Remove the four (two for each speaker) 5mm Phillips screws that secure the left and right speakers.
Conclusie
Steven Faulkner
490 Reputatie
4 handleidingen geschreven
USF Tampa, Team 16-6, Eyestone Fall 2016 Lid van USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 296
