Ga door naar hoofdinhoud
Dell Inspiron 9300 Modem Replacement
Wat je nodig hebt
  1. Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: stap 1, afbeelding 1 van 3 Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: stap 1, afbeelding 2 van 3 Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a size #0 Phillips screwdriver.
    • The screws do not come completely out.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
  2. Dell Inspiron 9300 Modem Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 9300 Modem Replacement: stap 2, afbeelding 2 van 2
    • Once the screws are loose, open the panel using a plastic opening tool to access the components below.
    • The modem card should be labeled MODEM. The WIFI card is larger than the modem and closer to the outer edge of the computer.
  3. Dell Inspiron 9300 Modem Replacement, Modem Card: stap 3, afbeelding 1 van 2 Dell Inspiron 9300 Modem Replacement, Modem Card: stap 3, afbeelding 2 van 2
    • Remove the screw holding the card in place using a size #0 Phillips screwdriver.
    • Gently unplug the card from the connecting black wire using a black spudger.
    • The modem can now be safely removed.
Conclusie
Randy McMillan
738 Reputatie
4 handleidingen geschreven
Master Techs Lid van Master Techs
Community
333 Leden
1.479 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 348
