Inleiding
This guide requires a Phillips #00 screwdriver
Onderdelen
Geen onderdelen nodig.
  1. Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Undo the screw on the Mini-PCI card cover labeled "C" This screw will remain within the panel
    • Undo the screw on the Mini-PCI card cover labeled "C"
    • This screw will remain within the panel
    • Remove the panel from the chassis.
  5. Disconnect the antenna cables from the Mini-PCI card.
    • Disconnect the antenna cables from the Mini-PCI card.
  6. Use your fingertips to carefully spread apart the white plastic tabs. Flip the Mini-PCI card up at a 45 degree angle. Remove the card from the computer by sliding out diagonally
    • Use your fingertips to carefully spread apart the white plastic tabs.
    • Flip the Mini-PCI card up at a 45 degree angle.
    • Remove the card from the computer by sliding out diagonally
    • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
charlierefvem
854 Reputatie
7 handleidingen geschreven
Cal Poly, Team 13-2, Forte Winter 2011 Lid van Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Leden
8 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 4
Afgelopen 30 Dagen: 9
Altijd: 4,011
