Ga door naar hoofdinhoud
Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement
Wat je nodig hebt
  1. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: stap 1, afbeelding 3 van 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: stap 2, afbeelding 3 van 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: stap 3, afbeelding 1 van 2 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: stap 3, afbeelding 2 van 2
    • Undo the screw on the Mini-PCI card cover labeled "C"
    • This screw will remain within the panel
    • Remove the panel from the chassis.
  4. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the antenna cables from the Mini-PCI card.
  5. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: stap 5, afbeelding 3 van 3
    • Use your fingertips to carefully spread apart the white plastic tabs.
    • Flip the Mini-PCI card up at a 45 degree angle.
    • Remove the card from the computer by sliding out diagonally
    • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
charlierefvem
854 Reputatie
7 handleidingen geschreven
Cal Poly, Team 13-2, Forte Winter 2011 Lid van Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 4,280
