Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will help you replace the RAM (memory module) on your Dell Inspiron 9100. It is useful to replace the RAM if your computer runs slower than normal or if your programs constantly freeze.
This guide requires a Phillips #00 screwdriver.
Wat je nodig hebt
Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
Pull the cover away from the laptop using your finger.
