Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
This guide requires a Phillips #00 screwdriver
Onderdelen
Geen onderdelen opgegeven.
  1. Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Nintendo Switch-kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Undo the two screws on the fan cover labeled "F2" These screws will remain in the panel
    • Undo the two screws on the fan cover labeled "F2"
    • These screws will remain in the panel
    • Remove cover plate.
  5. Remove the single 6mm screw holding the fan in place.
    • Remove the single 6mm screw holding the fan in place.
  6. Flip the handle up. Use the handle to pull the fan away directly up, away from case.
    • Flip the handle up.
    • Use the handle to pull the fan away directly up, away from case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
charlierefvem
854 Reputatie
7 handleidingen geschreven
Cal Poly, Team 13-2, Forte Winter 2011 Lid van Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Leden
8 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,104
