Ga door naar hoofdinhoud
Dell Inspiron 910 Web Camera Replacement
Wat je nodig hebt
  1. Dell Inspiron 910 Web Camera Replacement, Screen: stap 1, afbeelding 1 van 1
    • Using a plastic opening tool, pry the front silver bezel away from the colored plastic shell.
  2. Dell Inspiron 910 Web Camera Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the two screws using a Phillips #00 screwdriver from the metal casing that retains the screen.
  3. Dell Inspiron 910 Web Camera Replacement: stap 3, afbeelding 1 van 1
    • Pull down the laptop's back, keeping the screen upright, held in place by two metal strips going along its sides.
    • Unscrew the 4 screws from the two strips.
    • While unscrewing the second side, make sure to hold the screen so that it doesn't fall when the screws are removed.
  4. Dell Inspiron 910 Web Camera Replacement: stap 4, afbeelding 1 van 1
    • Gently lay the screen down, being careful not to damage the ribbon connector.
  5. Dell Inspiron 910 Web Camera Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the cord connecting the screen to the rest of the laptop. The cable will be attached to the screen using tape, so it can be safely removed. The actual cord connection is at the circuit board.
  6. Dell Inspiron 910 Web Camera Replacement: stap 6, afbeelding 1 van 1
    • Pull the screen out. Congratulations! You have removed the screen.
  7. Dell Inspiron 910 Web Camera Replacement, Web Camera: stap 7, afbeelding 1 van 1
    • Remove the two small screws above the screen at the center of the lid.
  8. Dell Inspiron 910 Web Camera Replacement: stap 8, afbeelding 1 van 1
    • Insert the replacement webcam module so the two screws match up with the two holes in the module.
  9. Dell Inspiron 910 Web Camera Replacement: stap 9, afbeelding 1 van 1
    • Replace and tighten the two screws so that the module is held in place.
  10. Dell Inspiron 910 Web Camera Replacement: stap 10, afbeelding 1 van 1
    • Carefully connect the ribbon cable running along the back of the screen to the appropriate docking station in the webcam module.
Conclusie
Arnesh Mudaliar
8 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-10, Forte Spring 2012 Lid van Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 1,837
