Ga door naar hoofdinhoud
Dell Inspiron 910 Speaker Replacement
Wat je nodig hebt
  1. Dell Inspiron 910 Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Speaker Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
  3. Dell Inspiron 910 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Lift up the keyboard using your fingers or a plastic opening tool.
    • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
    • Disconnect the cable by sliding the connector ears outward.
  4. Dell Inspiron 910 Speaker Replacement, Speaker: stap 4, afbeelding 1 van 1
    • After removing the keyboard, use the plastic opening tool or other form of leverage to remove the rest of the silver casing.
    • Depending on your model, there could still be some hidden screws on the bottom case of the laptop that hold the palm-rest in place.
  5. Dell Inspiron 910 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic tool to carefully pry the silver portion front of the top away from the colored portion.
  6. Dell Inspiron 910 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove the two small screws at the bottom corners of the speaker assembly.
    • Keep track of where you put the screws after you remove them. Keep screws of the same size together and away from screws of different sizes.
  7. Dell Inspiron 910 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Slide out the cables connected to the speakers and the base below the keyboard.
    • Remove the speakers from the laptop.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kyle Beekman
144 Reputatie
6 handleidingen geschreven
Cal Poly, Team 14-10, Forte Spring 2012 Lid van Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 19
Altijd: 1,606
