Ga door naar hoofdinhoud
Dell Inspiron 910 RAM Replacement
Wat je nodig hebt
  1. Dell Inspiron 910 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 RAM Replacement, Preparation: stap 2, afbeelding 1 van 1
    • Remember to power off the device before starting!
    • Disconnect any cables or external devices from the laptop, then flip it and remove the battery by pressing the battery tabs inward.
  3. Dell Inspiron 910 RAM Replacement: stap 3, afbeelding 1 van 1
    • Locate the large black panel with two screws holding it in place. (This is the panel with ventilation holes)
    • Unscrew both of the screws using a Philips Screwdriver.
  4. Dell Inspiron 910 RAM Replacement: stap 4, afbeelding 1 van 1
    • Remove the panel by pulling upward.
    • Removal may require some force!
  5. Dell Inspiron 910 RAM Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 910 RAM Replacement: stap 5, afbeelding 2 van 2
    • After removing the panel, locate the memory modules.
    • Look for the silver tabs on either side of the white plastic holding the RAM in place. Then gently remove the RAM.
  6. Dell Inspiron 910 RAM Replacement, For Reinstallation: stap 6, afbeelding 1 van 1
    • Depress the RAM until it locks into place; there should be an audible clicking noise when it does so and the gold contacts should be barely visible.
    • Congratulations! You have completed the guide.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kyle Beekman
144 Reputatie
6 handleidingen geschreven
Cal Poly, Team 14-10, Forte Spring 2012 Lid van Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 2,905
