Ga door naar hoofdinhoud
Dell Inspiron 8600 Top Case Replacement
Wat je nodig hebt
  1. Dell Inspiron 8600 Top Case Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Top Case Replacement, Power Button: stap 2, afbeelding 1 van 3 Dell Inspiron 8600 Top Case Replacement, Power Button: stap 2, afbeelding 2 van 3 Dell Inspiron 8600 Top Case Replacement, Power Button: stap 2, afbeelding 3 van 3
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Top Case Replacement: stap 3, afbeelding 1 van 1
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
  4. Dell Inspiron 8600 Top Case Replacement, Display Module: stap 4, afbeelding 1 van 2 Dell Inspiron 8600 Top Case Replacement, Display Module: stap 4, afbeelding 2 van 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Top Case Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Top Case Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 8600 Top Case Replacement: stap 6, afbeelding 2 van 2
    • Lift the display module directly upwards from the base of the computer.
  7. Dell Inspiron 8600 Top Case Replacement: stap 7, afbeelding 1 van 1
    • Now remove the display module.
  8. Dell Inspiron 8600 Top Case Replacement, Top Case: stap 8, afbeelding 1 van 3 Dell Inspiron 8600 Top Case Replacement, Top Case: stap 8, afbeelding 2 van 3 Dell Inspiron 8600 Top Case Replacement, Top Case: stap 8, afbeelding 3 van 3
    • First, remove all tabs using a flat head/ finger.
    • Next, remove all screws using a #1 Philips screwdriver.
    • Pull apart top case from the lower case. It will be quite difficult to separate.
  9. Dell Inspiron 8600 Top Case Replacement: stap 9, afbeelding 1 van 3 Dell Inspiron 8600 Top Case Replacement: stap 9, afbeelding 2 van 3 Dell Inspiron 8600 Top Case Replacement: stap 9, afbeelding 3 van 3
    • Remove all screws on the top of the lcd
    • There all several screw on each side of the LCD. Remove all.
  10. Dell Inspiron 8600 Top Case Replacement: stap 10, afbeelding 1 van 1
    • LCD should remove smoothly.
    • The top case will be what remains.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Perry
251 Reputatie
4 handleidingen geschreven
Cal Poly, Team 18-22, Garner Spring 2011 Lid van Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 2,162
