Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Follow this guide to remove the LCD Display.
Wat je nodig hebt
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
First, remove the plastic tabs that are covering the interior screws.
After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
Note there are 8 tabs and 8 screws in total.
