Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the battery from the bottom left of the laptop as shown.
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Pull the small black tab on the right hand side of the laptop.
You have now removed the hinge cover.
Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
Één opmerking
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
