Ga door naar hoofdinhoud
Dell Inspiron 8600 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 8600 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: stap 2, afbeelding 1 van 3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: stap 2, afbeelding 2 van 3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: stap 2, afbeelding 3 van 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: stap 4, afbeelding 3 van 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
Conclusie
Perry
251 Reputatie
4 handleidingen geschreven
Cal Poly, Team 18-22, Garner Spring 2011 Lid van Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Leden
16 handleidingen geschreven
Één opmerking
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 3,892
