Ga door naar hoofdinhoud
Dell Inspiron 8600 Display Removal
Wat je nodig hebt
  1. Dell Inspiron 8600 Display Removal, Battery: stap 1, afbeelding 1 van 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Display Removal, Hinge Cover: stap 2, afbeelding 1 van 3 Dell Inspiron 8600 Display Removal, Hinge Cover: stap 2, afbeelding 2 van 3 Dell Inspiron 8600 Display Removal, Hinge Cover: stap 2, afbeelding 3 van 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Display Removal: stap 3, afbeelding 1 van 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Display Removal, Display Module: stap 4, afbeelding 1 van 2 Dell Inspiron 8600 Display Removal, Display Module: stap 4, afbeelding 2 van 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Display Removal: stap 5, afbeelding 1 van 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Display Removal: stap 6, afbeelding 1 van 2 Dell Inspiron 8600 Display Removal: stap 6, afbeelding 2 van 2
    • Lift the display module directly upwards from the base of the computer.
  7. Dell Inspiron 8600 Display Removal: stap 7, afbeelding 1 van 1
    • Now remove the display module.
Conclusie
Victor
187 Reputatie
1 Handleiding geschreven
Cal Poly, Team 18-22, Garner Spring 2011 Lid van Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 21
Altijd: 3,930
