Ga door naar hoofdinhoud
Dell Inspiron 7586 2-in-1 SSD Replacement
Wat je nodig hebt
  1. Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: stap 1, afbeelding 1 van 3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: stap 1, afbeelding 2 van 3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: stap 1, afbeelding 3 van 3
    • Flip the laptop over so the bottom is facing up.
    • Use a Phillips #00 screwdriver to remove nine screws from the back case.
    • Insert an opening tool or spudger in the seam between the back case and the body of the laptop.
    • Work your way around the perimeter of the laptop and release the clips that secure the back case.
    • You will hear a clicking sound as the the clips are released and the back case is being removed.
    • Remove the back case.
  2. Dell Inspiron 7586 2-in-1 SSD Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 7586 2-in-1 SSD Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 7586 2-in-1 SSD Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the single screw securing the NVME drive.
    • Once the screw is removed, the SSD should pop up.
  3. Dell Inspiron 7586 2-in-1 SSD Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 7586 2-in-1 SSD Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 7586 2-in-1 SSD Replacement: stap 3, afbeelding 3 van 3
    • Gently slide the SSD out of the slot.
    • Make sure to gently pull out the drive to avoid damaging the M.2 slot where you insert the new SSD.
  4. Dell Inspiron 7586 2-in-1 SSD Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 7586 2-in-1 SSD Replacement: stap 4, afbeelding 2 van 2
    • Align the tooth edge of the SSD with the indents on the drive socket and gently insert the replacement SSD.
    • Press down on the SSD so the screw hole and drive align.
    • Use a Phillips #00 screwdriver to replace the screw.
    • Don't be scared to push down on the SSD as it should be level with the rest of the components.
Conclusie
Mike03
139 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 37
Altijd: 445
