Ga door naar hoofdinhoud
Dell Inspiron 7568 Display Assembly Replacement Guide
Wat je nodig hebt
  1. Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: stap 1, afbeelding 2 van 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Display Assembly Replacement Guide: stap 2, afbeelding 1 van 2 Dell Inspiron 7568 Display Assembly Replacement Guide: stap 2, afbeelding 2 van 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: stap 3, afbeelding 1 van 2 Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: stap 3, afbeelding 2 van 2
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
    • Doing this will allow one to access the LCD-motherboard connector cables.
  4. Dell Inspiron 7568 Display Assembly Replacement Guide: stap 4, afbeelding 1 van 2 Dell Inspiron 7568 Display Assembly Replacement Guide: stap 4, afbeelding 2 van 2
    • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
  5. Dell Inspiron 7568 Display Assembly Replacement Guide: stap 5, afbeelding 1 van 3 Dell Inspiron 7568 Display Assembly Replacement Guide: stap 5, afbeelding 2 van 3 Dell Inspiron 7568 Display Assembly Replacement Guide: stap 5, afbeelding 3 van 3
    • Disconnect the antenna cable (under the left hinge)
    • Disconnect the LCD and Touchscreen display cables under the right hinge.
    • These are a set of two cables. For better image see image two in step one of this guide.
  6. Dell Inspiron 7568 Display Assembly Replacement Guide: stap 6, afbeelding 1 van 1
    • Carefully separate the screen from the bottom half of the device.
Conclusie
Yash Samant
394 Reputatie
3 handleidingen geschreven
USF Tampa, Team S2-G2, Lacy Spring 2017 Lid van USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 1,062
