Ga door naar hoofdinhoud
Dell Inspiron 7486 Chromebook Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 7486 Chromebook Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 7486 Chromebook Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power off your Chromebook and unplug it from the AC adapter before starting.
    • Remove the seven 6 mm screws securing the base cover with a Phillips #1 screwdriver.
  2. Dell Inspiron 7486 Chromebook Battery Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 7486 Chromebook Battery Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the three captive screws with a Phillips #1 screwdriver.
  3. Dell Inspiron 7486 Chromebook Battery Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 7486 Chromebook Battery Replacement: stap 3, afbeelding 2 van 2
    • Gently pry the base cover loose at the hinges with a plastic opening tool.
    • Carefully run your fingertips along the edges of the base cover to remove it.
  4. Dell Inspiron 7486 Chromebook Battery Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 7486 Chromebook Battery Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 7486 Chromebook Battery Replacement: stap 4, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, remove the two 4 mm screws securing the battery cable bracket to the motherboard.
    • Remove the battery cable bracket.
  5. Dell Inspiron 7486 Chromebook Battery Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 7486 Chromebook Battery Replacement: stap 5, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove the four 3 mm screws that secure the battery to the motherboard.
  6. Dell Inspiron 7486 Chromebook Battery Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron 7486 Chromebook Battery Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron 7486 Chromebook Battery Replacement: stap 6, afbeelding 3 van 3
    • Pull the tab on the battery cable to disconnect it from the motherboard.
    • Remove the battery.
Conclusie
4 andere personen hebben deze handleiding voltooid.
[deleted]
265 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 54
Afgelopen 30 dagen: 176
Altijd: 1,410
