Ga door naar hoofdinhoud
Dell Inspiron 700m Hinge Cover Replacement
Wat je nodig hebt
  1. Dell Inspiron 700m  Hinge Cover  Replacement, Removing battery: stap 1, afbeelding 1 van 1
    • Remove the battery by sliding and holding the battery release latch.
    • Make sure your computer is turned off and unplugged.
  2. Dell Inspiron 700m  Hinge Cover  Replacement, Open display: stap 2, afbeelding 1 van 1
    • Open the display 180 degrees.
  3. Dell Inspiron 700m  Hinge Cover  Replacement, Removing Display: stap 3, afbeelding 1 van 1
    • Use a plastic flat screwdriver to slide the hinge caps away from the computer.
    • Detach the two display latches on the back of the computer.
    • Use plastic flat screwdriver to carefully pry up the latches on either side of the hinge cover
    • Carefully, lift the hinge cover from the main unit and remove it from the main unit.
Conclusie
irlanda
12.231 Reputatie
2 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.996 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 238
