Inleiding
You will need a Philips screwdriver, an anti-static wrist strap, and a wedge type tool such as a flat-head screwdriver. This guide will walk you through how to replace the LCD screen on your Dell Inspiron 600m.
Gereedschap
Onderdelen
Push in the tab on the battery and lift up. The battery should detach very easily.
Locate the rubber dots on the plastic around the lcd panel.
Use your fingernails or a flat-head screwdriver to remove the rubber dots around the screen by pushing any direction on them.
Underneath the rubber dots will be screws. Remove them with the #00 screwdriver.
4 andere personen hebben deze handleiding voltooid.
