Ga door naar hoofdinhoud
Dell Inspiron 600m Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 600m Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Inspiron 600m Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Inspiron 600m Hard Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Hard Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 1
    • The hard drive is located here.
  3. Dell Inspiron 600m Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
  4. Dell Inspiron 600m Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Todd
146 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-40, Forte Spring 2011 Lid van Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Leden
8 handleidingen geschreven
2 opmerkingen
What size is the hard drive, you know, to buy a new one?
Ethan White - Antwoord
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 44
Altijd: 17,323
